I have a tilt and trim unit that was contaminated with water pretty badly. Is there a way I can flush this out without removing the tilt and trim from the motor? Can I use any fluid just to flush then replace with Yamaha? I already wasted a bottle thinking I got all of the old fluid out, it quickly got contaminated and now I had to remove that.
I replaced all the seals and O rings on the main piston and the smaller rods.
Thank you
Thank you
