If you do as I did, flip the carb over, float bowl off, float and needle in, it'll be in the closed position.
I use an extra fuel tank (small from an old lawn mower for diagnostic purposes).
Hook up fuel to the line to the carb.
If you lift the float (open) fuel will flow obviously. If in the closed position, it still leaks fuel, the needle is not seating fully (like my above Honda mower) and will flood.
Wether the new needle has a rubber seat built into it or the carb itself does, I don't know (one will). If a new needle passes that test, that part of the carb should be ok.. If its real sloppy in there, it likley won't seal well..
Very simple test
Please post what you come up with.
Very simple test
