bobs machine shop sportsman nose cone and pickup. any one have any first hand experience ?
bobs machine nosecone and low water pickup
If you are asking about speed, I belie it helps 60+ mph boats more than slower ones.
On my Hydrostream Vking w/225 Excel I only picked up 2 mph over the stock lower unit (87 to 89 mph). A bit more stable also as I could raise the motor higher. Also mine had a torque tab on the skeg which helps some with the steering torque since the regular trim tab is out of the water.
However, I need to do some more testing as I was tickling the rev limiter. (need to snip the wire)
