gasket leak on a 2006 Yamaha 50tlr
  • gasket leak on a 2006 Yamaha 50tlr
    I have developed a very small leak around the gasket on the plate with the manual choke. I was told by a dealer I needed to replace both gaskets and the diaphragm, is there really a need to tear it apart to replace the diaphragm or can I just remove the front gasket that is leaking and be done with it? The auto choke is working find the way it is.
    maybe he wants to rack up a big bill$$$$....seems like that gasket is what needs replacement ...
      Which part is leaking, (part # please):
      https://www.boats.net/catalog/yamaha...lr-0409/intake
      As you have Prime Start: https://www.boats.net/catalog/yamaha...409/carburetor I'm not quite sure where your leak is..
        It's leaking behind part number 29 and part number 42.
          on the diagram with prime start, doesn't show it on the first link, thanks
            Are you able to fix it yourself? Looks like two gaskets, a diaphragm... $30? Very simple job. It will be like new again...know what you have then. Leaking gas in an in closed space is never a good thing.
            Have a go at it youself.
