I have a Yamaha F80 BET and I am having problems with the tachometer, it goes dead but when I turn the steering wheel to turn the engine in one direction the power to the gauge comes back on. Also when the power to the tachometer is gone the engine will not turn off even when the kill switch is removed. Any help would be appreciated. JOHN
Multifuction tachometer gauge problem
At least remove the cowling and check the ten pin harness to motor harness connector. Should have a bayonet lock holding it together. Some how, some way, it might be loose and when the motor is turned the ground connection is lost/intermittent. Not likely but this is a two minute inspection.
What type of throttle/shift control do you have and what type of steering mechanism? Might want to check all ground connections up at the helm.
