05 200 tlrd
  • 05 200 tlrd
    What would cause motor to not run over 5200 rpm @ wot? This has happened out of the blue.
    ALL filters have been replaced in the last 8 months, no issues prior.
    Never had a problem with this motor.
    200 approx hours on motor.
    something wrong with boat, set up, prop, or motor.
    Look things over to see if something has physically changed,
    Could your bilge be full of water and you are carrying a lot more weight now?
    Just because the filters have been changed months ago does not mean they are not a problem now. does not take but a minuet to run a bunch of crude into the fuel system. Test fuel pressures to see if they are staying in spec is the easiest thing to do when having fuel problems
