1996 Yamaha Pro 60 Tiller warning buzzer
    Originally posted by walleye1 View Post
    Didn't it depend on the hp?
    Depends upon the model. TLH models come with a tiller handle. THR models come without a tiller handle but can be retrofit with a tiller handle.
        We would order an engine in and install a handle kit with no horn. The engine came with a harness and a horn
        but tech support could not tell you how to hook it up inside the cowling with a handle.
        • #19
          Where is the horn?
          • #20
            Where is the horn?
            From the Yamaha parts book I cannot tell. I am waiting on the OP to tell me where the pink wire goes. Should go to the buzzer. Or where a buzzer was mounted.
            I think.
            • #21
              Maybe the buzzer is mounted outside of the motor. Like a tachometer would be.
              • #22
                Most boats I rigged did not have a tach. I started to wire them inside of the cowl.
                • #23
                  How did the user view it?
                  • #24
                    Were the motors an H or a R model?
                    What did you do with the external wiring and horn?
                    was the rest of the external wiring harness for a tach?
                    • #25
                      I am at a loss in finding those wire pigtails ( yellow,pink) I will look again this weekend and hopefully have success in locating them. When i do I will report back. Thanks for all the info !
                      • #26
                        Do you see the wire harness that comes out of the motor? Item #20 in the illustration?
                        • #27
                          I thought it showed #18 coming out of the front of the motor and # 20 plugged into that
                          • #28
                            It is item #20 that I am talking about. Wherever it is located. Inside or outside the cowling.
                            • #29
                              Boscoe,
                              I located the wires coming out of # 20. Now I will get a warning buzzer and figure out a place to mount it. Thanks for all your help and input. I will have peace of mind knowing I will have a warning buzzer.
                              Thanks again !
                              • #30
                                Originally posted by JPJ View Post
                                Boscoe,
                                Thanks again !
                                Hold on now you cannot just leave without telling us where those wires are located and where/ what the rest of that wiring harness goes to
