You probably know J1939 is like "NMEA 2000 for diesel trucks buses and trains" -
although it came first -
the NMEA 'copied from it' for NMEA 2000;
publishing this is 1999:
So modern "marinized" diesel engines use J1939, but apparently because the market is small,
have been largely ignored by the recreational electronics manufacturers - Furuno, Simrad, Garmin etc.
However, about 3 years ago, Garmin offered a "J1939 capable" version of their GPSMAP 7000 series MFD -
and later included it as standard - in addition to NMEA 2000 capability -
so on some Garmin MFDs, there are two identical DIN connectors,
one labeled NMEA 2000, the other J1939.
The reason we are hearing about it now -
for some unexplained reason,
when Yamaha allowed Garmin, Furuno and Simrad to 'emulate' the Command Link display -
Furuno and Simrad did it via the Yamaha "Gateway" to a NMEA 2000 backbone
(and of course a software update)
but Garmin chose to require connection to that 'J1939' plug in order to enable the emulation.
(and maybe also need a Yamaha Gateway - but I don't recall - it confuses the sh*t out of me)
At this point, all Garmin marine plotters (except their 4" unit) have a NMEA 2000 port -
but only a few have, in addition, the J1939 port.
Sadly, regarding documentation of the Yamaha "emulation screen" -
they have mirrored Yamaha's style: murky, and incomplete.
The Garmin documents:
- specify that the J1939 port must be used to get the Yamaha screen
- specify that their cable goes from the J1939 port "to the Yamaha hub" (via a Yamaha pigtail cable)
- do not indicate that a Yamaha Gateway is required in between
- do not reference any distinction between whether the Yamaha hub is CL or CL+
So it would seem, that the J1939-equipped Garmins will display the Yamaha screen
when directly connected to either CL or CL+
But I have no way to be 100% certain;
unfortunately,
I purchased my current Garmin MFDs before the J1939 port was added to those models -
so I am unable to get empirical data.
(and lack access to a DEC engine, anyway)
Thanks. This is getting a tad less fuzzy to me thanks to your help.
I think that the emulation of the Yamaha display is what is driving this. Versus seeing just engine data in a number of other ways. J1939 to see data in the Yamaha CL+ format versus seeing data in a non-Yamaha CL + format via NMEA 2000.
Aren't you thinking that you really really need a new Garmin display? One with a J1939 port? And while you are buying it, isn't it time for you to have a new Yamaha DEC model so that you have both CL and CL+ ports available?
