I am a newbie to outboards and am doing a bit of maintenance to my motor. I see the single inline fuel filter (strainer) and am unable to locate another. Does this motor have another fuel filter?
I didn't see the title info. You can install an aftermarket fuel-water separator in the fuel line prior to your fuel line bulb if desired. Sierra makes one for around $50 - $60.
Thanks folks. I found it interesting that this motor has only the inline filter (strainer). It has been replaced, along with all the fuel line and the bulb. yay. I don;t see a need for a separator . . yet. I use only non-ethenol fuel. If a problem arises then I may install one.
Actually the addition of the water/fuel separator would be easy and excellent preventive maintenance...the Walmart/Attwood unit for $28 would work fine....
And WELL worth the investment! A 10 micron is the norm...
