703 side binnicle
  • 703 side binnicle
    Relaced tilt/trim switch as the up showed no movement on the voltmeter. Still the same after replacement. Whats next, Relay? and where is it located?
    no relay operating voltage from the switch?
    why would I suspect a bad relay?
    I may suspect a bad switch or switch connection or maybe switch supply voltage but not a relay yet.
    if we had an engine model number we may be able to tell you how to test the relay.
      volt or ohms testing depends on where you are taking readings when testing.
      I myself would have been voltage testing at the relay to begin with, and then move through the system wiring.
      follow the T&T motor wires, they will land on the relay, even if no one but you know what motor you have hooked the these controls
