Thanks for all the help everyone. The stator came today and fixed the problem.
99Yam- I was using a fluke meter with peak hold. And I was using DC not AC as previously stated. Funny thing is that the charge Coils did test good resistance and got 177/55 volts for the high and low speed. I did not get a chance to try the loaded test. In retrospect that probably would have revealed the erroneous positive results. Though banking on the symptoms I was led to believe that the charge Coils could not cause this problem.....
After seeing everything working, I went back in and reinstalled the original pulser, CDI, and cps. All is well. I'm going to try to megger the old stator and see if there is a bad connection within.
Bottom line is that a bad charge coil did somehow cause me to lose spark on 1-3-5. I'll let you experts debate on how that's possible. Boscoe was the only one that gave a plausible explanation. Thanks for that!
Many thanks to all for the input.
Joe
Joe
