Bravo three question Rodbolt sorry not a yamaha question
  • Bravo three question Rodbolt sorry not a yamaha question
    What is the difference between high bump and low bump gears in the upper drive?
    Probably cleaning his guns from his shoot today. Might be morning with coffee to see this.
      Where is everyone today?
      out shopping all of the sales?
      Too dang windy and cold around here to be out on the water.
      Is there actually a difference in the gears or is it just the shifter and bushings that make it easier to bump into gear?
        I am going to call mercury to see what is up, i don't want to order the wrong gear kit at almost 2k.
          I got to go plow snow after the phone call.
            Just turned the A/C, low 80'sF..
              I am ready for shorts weather
                Heck, supposed to be close to a record high today, 88F!!!!! Friggin summer already....
                It never broke 40F this past winter-which it did, kills off certain weeds...
                  10 degrees here this morning
                    It is 50 here on the TX coast this morning and sprinkling rain
                      if you are ordering a gear set it wont matter.\
                      the difference was in how the shift cone and shift slide were made.
                      what you will need from merc is the new shim procedure.
                      the only time the shift BUMP would come into play is if you were replacing an individual part.
                        Thank you Rod, there is a sb on that kit that tell's what shims to order compared to the old ones.
                        What is flat rate to rebuild an upper and clean out the lower?
                          to much saltwater to flat rate around here but typically if you have the correct tools it takes about 6-8 hours.
                            Thank you Rodbolt
