What is the difference between high bump and low bump gears in the upper drive?
Bravo three question Rodbolt sorry not a yamaha question
Where is everyone today?
out shopping all of the sales?
Too dang windy and cold around here to be out on the water.
Is there actually a difference in the gears or is it just the shifter and bushings that make it easier to bump into gear?
Originally posted by walleye1 View PostI am ready for shorts weather
It never broke 40F this past winter-which it did, kills off certain weeds...Scott
if you are ordering a gear set it wont matter.\
the difference was in how the shift cone and shift slide were made.
what you will need from merc is the new shim procedure.
the only time the shift BUMP would come into play is if you were replacing an individual part.
ÂÂÂÂÂ
