I have this motor that will run great in neutral from idling all the way up the RPM range and will run great in gear until full throttle. Once the engine is at WOT the engine will run for a while, hesitate and die. It will usually start right back up.
At first I thought it might be a fuel issue so I replaced the gas tank and gas line with brand new products. That did not help.
So then I thought it might be a cooling issue so I replaced the t-stat and flushed out the cooling system.
That did not work, so I replaced the coil thinking that it might be weak and not working properly when the engine gets hot, but that did not help either.
I tried searching on this forum and on google for any similar cases, but I don't see any.
Any help would be greatly appreciated.
