Got my high end RPm loss of power problem back. New filters in Sept, VST, inline, canister and separator. No more than 20 hours added since then, was running great up to last evening.
Couple of questions about fuel pumps.
The gauge I hooked up to the low pressure one idles at 50 psi, then when i open up the throttle it drops to 40, comes back to 45, drops to 40. Is this too much of a variance off the 50 ? Is 50 the correct number it should run at ?
Also, should there be any residual pressure when I turn the motor off? Its goes straight down to 0.
What would be your first things to do ?
As always thank you
Signed: one FRUSTRATED HPDI owner
As always thank you
