So still working thru this motor...….. came across this. Seems the previous owner drilled and tapped a hole in the thermostat housing ran a housing from the nipple to the tell tale. Any idea why? Some "performance" upgrade? The flush kit hose from the exhaust cover is just pinched off since the flush kit is missing as well.
"Custom" thermostat?
If not using muffs, (even if so), you may want to put the factory flush parts back on.
If he had a hose connector connected to his "modification", I'd guess it'd be to fresh water flush around the thermostat.
I have no idea what he was attempting to do. Show water is making it to the top of the powerhead?Scott
Originally posted by BQUICK View PostI've run a hose between t-stat housings so water can cross over up top as well as lower crossover which often ends up clogged. Greatly aided cooling on older motor with semi clogged system.
And though maybe you had sold the motor to the OP
Originally posted by zenoahphobic View PostProbably usefull for all of the above.
I like the idea that you can reverse flush through that fitting, albeit slow through the only small hole in the thermostat as the thermostat will be closed with cold water.
Actually, on the other side of the thermostat (in the block) is where the bad corrosion occurs. Even with "this set up", when using the factory flush(not even installed), water is still AWAY from the block (wrong side of the thermostat)
With that said and the way it's hooked up, seems to be a homemade tell tale (as the factory set up is clogged/ not working).
**I like the idea posted sometime ago about opening up the thermostat vent hole a tad to allow fresh water to get in that area prone to corrosion (with the thermostat closed).
Obviously not too big to make the thermostat useless....Scott
So it sounds like it’s not a bandaid fix something else then? Would rather not have to buy a new thermostat housing but want it correct. It’s not bypassing the thermostat or reducing the cooling I take it.
Where does the normal tell tale come from on these then?
Originally posted by mitch184 View PostSo it sounds like it’s not a bandaid fix something else then? Would rather not have to buy a new thermostat housing but want it correct. It’s not bypassing the thermostat or reducing the cooling I take it.
Originally posted by mitch184 View PostSo still working thru this motor...….. came across this. Seems the previous owner drilled and tapped a hole in the thermostat housing ran a housing from the nipple to the tell tale. Any idea why? Some "performance" upgrade? The flush kit hose from the exhaust cover is just pinched off since the flush kit is missing as well.
[QUOTE=mitch184;n213484]So sounds like it may have been done to mitigate potential cooling issues and it's fine to leave as is? QUOTE]
Does sound like it. As you don't need the flush kit, I would find out how the engine tell tale SHOULD BE SET UP and correct it accordingly.
You can simply cap off that fitting but Yamaha didn't design that cover for a tell tail hose..
It can very well be hiding an issue (clogged hose, WP, ??). You'll only know once the engine hoses are set back up correctly...
*I'd be curious if there's even a thermostat under the cover. I'd definitly pull the cover (or hose) and see if there's one there.
You REALLY SHOULD have a thermostat installed...Last edited by TownsendsFJR1300; 01-31-2019, 08:49 AM.Scott
