Originally posted by dark_star
View Post
90TLRD Prime Start Issue
Well first thing I check was the prime start solenoid, there was 0 connectivity between blue and ground wires. I hooked up blue to the positive and black to the negative and nothing extended. It actually looks like the needle is stuck down in the housing. So new solenoid is a given.
going through all the grounds now and cleaning carbs.
Originally posted by 99yam40 View Postwhen you hook the wires to a 12 volt source, it takes awhile to the unit to heat up and push the needle out a small amount.
I hope you are reading all of the info in manual on testing along with other procedures
Originally posted by mitch184 View Post
The needle didn't come out with the electrothermal valve... I'm trying to figure out how to post the picture now. With an ohm meter on the black and blue wires it show no connectivity or 0 ohms. I did hook up the wires for about 5 minutes and saw nothing.
OL is an open, (no connection) very high resistance
