A cracked impeller brass ring while deep drop fishing in the devils triangle...
I would not replace the lower unit unless I had a spare one lying about.
I'd drain the oil. Consider remove the four bolts and the seal carrier. Bring the lower unit to a TIG welder, along with the new key in hand. Have them lay a bead or two on the sides of the slot only. You are going to want some real material to hold that key. My thoughts are that the JB alone would likely turn to paste in short time. Now the weld does not have to be perfect. Perfect is the enemy of good enough. You need enough weld to hold the key perpendicular and solid, the rest can be JB Weld... hand file, grind, and sand the weld smooth.
Install a new seal(s) regardless of its perceived condition (seals? Do the have double (two) lip seals?)
Let us know how the saga ends. I love a happy ending... ( as does Bob Kraft, assumedly)
