I have a 2004 sx 200 that starts and runs fine until you stop. wait 30-45 min and try to start the motor and it will not. the engine turns over fine, you can pump the bulb and it will not start. You can spray carb cleaner in the air horn and the engine will try to start but drop dead. wait 15 minutes and the engine starts and runs fine. I have changed the vst filter, the bowl filter, primer bulb, and the fuel pump diaphragms. Question is there something in the injection system electronics that would prevent injection of fuel on a warm start?
this issue is intermittent and does not happen all the time.
