I have a 2001 Yamaha TLRZ 115 2 stroke, I would like to know which screws on the carbs are considered the drains
yamaha carb
On my C90 Yamaha the carb drain screws have 10MM brass hex heads and are located on the lower side of each carb float chamber. There may be other types on other motors like a brass slot head screw....Tip:Always put a rag or towel under each carb when you remove drain screws to catch the fuel, any debris/dirt, and of course the drain screw....which is easy to drop!....
