I have a '92 70hp that I am putting carb kits on. Before I pulled off the cover on the 'enriching pump' I removed the red lever on the shaft that goes through the cover and into the pump (this is the lever to prime for manual start). When I removed this, I did not realize the shaft had grooves cut in part of it.
Question is: When in normal running mode (open position on the pointer), do the grooves face the 1:00-2:00 position? Or, should they be in the 7:00-8:00 position. This really isn't shown well in the Yamaha manual.
Thanks,
Ed
Thanks,
Ed
