I have an older model multifunction tach on a 1993 130hp. I think that it is a 6y5-83500-03-00. I am looking for a way to test the oil level lights and warning buzzer. The tach and trim level is working fine. I assume the warning lights simply light up when needed. Is there a warning buzzer for each color light? Can I test each light by moving float in oil tank? What does each light mean? If oil level is fine should the green light be on? I assume yellow is past a certain point in the oil tank. Does red come on when very low in big oil tank or low on reservoir on motor? do you know if there are any manuals on this gauge out there anywhere?
thanks,
GLS
thanks,
GLS
