My engine got stuck twice in the elevated position two days in a row. The tilt worked fine up until I raised the engine in shallow water and then nothing. I could hear the solenoid (sp) click at the engine. checked all the fuses (under helm and on engine) all good.
I was able to get out to deeper water and increase RPM and the bow shot up out of the water after a 30 seconds or minute I was then able to lower the tilt and the raise and lower worked fine on the outboard no problem. Then worked fine rest of afternoon. Then it did the exact same thing the next day. It seemed to start working when the engine was operating at an increase RPM; it might take a try or two to get on plane then it would work
When I was operating the title with the engine off it sounded very labored when I used the manual switch on the outboard; almost like out of power.
Any ideas? I was thinking the solenoid may be going bad or my battery is not good. The batter is less than a year old.
Any ideas would be greatly appreciated.
