Hi!
I have the following problem: I have a new F115 (2013) and a command link hub (currently with no free device connector; I have installed the 2 Yamaha gauges and the security system) and a Raymarine a78 plotter.
I want to bring the engine data on the a78 display. Therefore I have to convert the command link to NMEA 2000. I have already bought the 0120-37 cable, because it is not easily possible to buy the MAR-GTWAY-ML-09 from Yamaha ... rather impossible here in Europe.
Can I connect the 0120-37 also directly to the command link hub? What is the difference between the 0120-37 and the MAR-GTWAY? Does anybody know it?
This afternoon, I have tried the following: I disconnected the security system to the free place on the command link hub. Then I put the 0120-37 on it and on the other side I put the NMEA 2000 connector to a special Seatalk NG network from Raymarine which provides a NMEA 2000 connector. And, it was possible to see the engine data on the a78 display.
BUT, unfortunately I had the following sideeffects:
a) In one of the Yamaha gauges the engine symbol flashes. I think this is why the security system was disconnected. This can be resolved if I will buy an other command link hub to provide a free device connector on the hub.
b) The Yamaha gauges were already on after turn on of the battery switch, which ignition still off. For this behavior I have currently no explanation.
What do you say? Am I on the right way, or is the connection of the 0120-37 directly to the command link hub not possible?
Regards, Helmut
Regards, Helmut
