Originally posted by TownsendsFJR1300
View Post
2013 f300xca - water in oil
Originally posted by panasonic View PostI got my doubts you will see that block again. Yamaha don't want pictures of a cracked block on a 5 year old expensive motor kicking around the Internet. Bad for business.That is my guess.
Not trying to bash or spread FUD. I'm a bit of a tech nerd & gearhead, and my only interest here is in understanding the issue and helping others. I'm a big fan of "learn how things work and fix them when they break". Not a fan of the throwaway culture we've become...I was raised to understand, maintain, and fix, and looking at failures is the only way to understand them. EVERY manufacturing process churns out duds from time to time. Anyone who says otherwise is misinformed or lying.
Either way, I'll post an update.
Just curious, very odd of a failure as such... I can understand Yamaha not wanting a picture floating about.
I suspect (when you pick up the boat), can point out what broke on the block.
And buy a lottery ticket, you got lucky!!!Scott
Originally posted by Humpty12 View Post
That could very well be the case, but they're doing right by me, and that is something that is a pleasant surprise. In a world where I'm constantly disappointed by terrible customer service, Yamaha is really a ray of sunshine for me today. Hats off to them.
I hear you on the throw away society we have created...making the world one big garbage dump.
my guess is that head failed to drain and froze once. that is usually where the freeze crack.
at the bottom of the head there is a drain hole slightly smaller than a pencil.
if it clogs,and they do, that head wont drain.
holds water all winter.
makes aa mess later.
Originally posted by rodbolt17 View Postmy guess is that head failed to drain and froze once. that is usually where the freeze crack.
Could be , but he said the motor has lived in florida, but that does not mean someone did not carry it farther north some time in cold weather
As long as Florida is, a three hour ride north (during the winter) can make a BIG difference in temp.
For RodBolt, will tilting that engine drain the area that likely froze or do you have to inject anti-freeze somehow?Scott
It gets to freezing temps, usually once or twice a year (winter) even in SW Florida. Central and northern Florida, MORE often.
how else can you be sure
Originally posted by pstephens46 View PostNever read where Rodbolt or anyone else mentioned freezing issues on the V-6. The V-8 has been mentioned many times. Is this something new?
IE, What's the preventive procedure?
How would you inject antifreeze? A small, electric water pump attached to the "power head flush hose" with a pick up line in pre-mixed Prestone?Last edited by TownsendsFJR1300; 12-30-2018, 10:50 AM.Scott
Originally posted by 99yam40 View PostI guess this is a V6 , so #4 is not on the bottom, but in the middle on one sideScott
