Update - I've been informed that there is a small crack in the block which is the source of water in oil. Waiting to see if Yamaha is going to step up and goodwill parts/labor or both.
2013 f300xca - water in oil
Originally posted by 28Regulator View PostNot sure what can cause a cracked block, but there has been some chatter that freezing temps can do it - even if the lower unit is all the way down, in F300s and F350s. Was yours ever wintered without running antifreeze thru it?
Originally posted by pstephens46 View PostPost up some pics. We would all like to see the location of the crack.
Originally posted by 99yam40 View Postinteresting, I could understand a flaw being covered by warranty,
but after 5 years a crack magically shows up.
not sure about that
Lets get Solo going Yam. Smoked a nice pork butt yesterday. Publix had a sale. Bark turned out nice. Butts are an easy, cheap cook. Hard to find a good 10-12 hour window to do a brisket.
I picked up 4 whole butts here lately.
2 were .99@ lb in Nov and the other 2 were .79@lb last week.
if my brother does not shoot and give me some deer meat, i will use some briskets I picked up for $1.47 @lb to mix with the pork to make link and summer sausage
I thought the Butts took a long time also to break it down well when smoking
yep smaller pieces take less time to get to proper temps.
I do my briskets around 220-230 for over 12 hrs.
part them If I want to speed things up some
do you put much more than the a dry rub on your butts while cooking?
I do not for my briskets, but I do wrap them in foil for the last 4 hours or so,
I also put water pans in the smoker before wrapping to keep from drying out too much.
and what do you add after cooking if any?
just save the drippings for that?
Originally posted by 99yam40 View Postyep smaller pieces take less time to get to proper temps.
Man, I do love BBQ. Personal choice is beercan chicken and ribs. Low and slow on the webber. I need to invest in a good smoker. My last one disintegrated. If you're ever in the Memphis area, and you like dry rub, try Rendevous. Also, Commissary is fantastic.
Also - Yamaha stepped up, and they're providing a new long block, 10 hours labor, and an oil change. If I happen to see the rep, they're getting a hug. I'm honestly shocked, and they've just won a customer for life. Shop has to hold onto the block for 3 months, but as long as Yama doesn't ask for it, I'll scoop it up, tear it down, take photos of the damage, and post it here.
