I think Fairdeal's last sentence says something: What is a "real" load for the setup?
There seems to be some pondering about what happens to the power; there is simply not much created when the wires are shorted. Boscoe says 34 amps and later advises at less than one amp. That equates to to less than 34 watts. One can say that that generator is not working effectively, "cavitating" if you like with a hopelessly mismatched "propellor". Or look at it as if the engine is revving at full power revs but in neutral, say 6000rpm but putting out very little power,
What happens to the excess power? It is dissipated or shared between the regulator and the windings, as I mentioned previously, in (inverse) ratio to their respective resistance.
