Ok guy's really hope I can get this solved. Having a issue with a high idle(1200 rpm's) and won't rev over 4200 under a load. Parts replaced low pressure fuel pumps, VST filter, on the motor fuel filter, water separator filter and housing, spark plugs and a cleaned O2 sensor. What I have found is even after pumping the bulb when the motor starts the fuel level in the on the motor fuel filter drops down to about 2/3's full and that's when it idles high and won't rev over 4200. Now if I pump the bulb when the motor is running the on the motor filter will fill up and the idle drops down to 700 and she will rev out to 5500 and runs like a raped ape. Fuel pressure is at 36 psi at idle even when acting up. The guts to the check valve between the on the motor and low pressure fuel pump have been removed. Not sure how to go about isolating why the level of fuel in the on the motor pump drops after its started after its off for more then 15 or 20 minutes. Oh yea compression is between 120 and 125 on all cylinders. Thanks for the help guy's.
Don C
Don C
