So i pulled my spark plugs out the other day doing some general maintenance and i noticed one was clean like it came out of the box. So i did a compression check and they all came back in the mid 90's. Next i hooked up an in line spark tester and i had spark. So then i i let the motor run and sprayed some wd40 in the carb to see if the idle changed. No change except for some smoke, so i think i have covered the basics (compression, spark, and fuel) so i think it must be getting water in there via the head gasket. Am i on the right track? The motor is an 150 extd 1990 and the head gasket has never been changed.
