Thanks to all who offered advice/suggestions regarding my issue. I thought I would provide an update given that my mechanic has hooked up the PC to see what was going on. First thing we discovered is it is the starboard engine that is burning more fuel. When connecting the wire leads to the Command Link apparently someone had the starboard engine and fuel tank represented by the fuel gauge on the left! He analyzed both engines' plugs and saw 2 from the starboard engine that were worse than the others.
My installation of the new spark plugs were all ok.
With the new spark plugs in and the PC hooked up it
revealed that the starboard injectors were open longer - about 8.5 millisecs and the port injectors open 7.3millisecs (I think I have that right) at my normal cruise of 3600 rpm. We are going to replace the VST filters as start and take a trip and see how that does. If still a major difference he is thinking the injectors or injector screens may be a problem. He thought those scenarios may be more likely than a bad Oil Control Valve (OCV, which Yamaha calls an "oil solenoid if you're looking for it on their engine schematics). I have always bought fuel from the same gas station since I have owned the boat but fill tanks using 2 different hoses (therefore different dispenser filters). If dirty gas or tank bottoms I would have thought it would affect both engines but who knows...
