I think a lean mixture burns slower because, although the same amount of oxygen molecules are present, they need to travel further to "mate" with lesser HC molecules in the same space.
Where this leads to an economy limit, I think is due to the corresponding slower rate of gas expansion able to be harnessed as the piston moves down at the explosion or power stroke.
In a carbon free clean/new engine, if not the spark plug, a very hot exhaust valve can be a source of ignition. It can be red hot and may just ignite the first few mixture particles getting to it before they cool the valve; the inlet valve still being open. There does not necessarily need to be any overlap where both valves being open briefly at the same time.
I guess newer engines thus pose a design challenge, because of wanting hotter running for efficiency, good swirl aerodynamics for power and efficiency, increased intake speed for more power, and the getting rid of the increasing no longer wanted heat after each burning cycle out of the combustion chamber. Higher temperature resistant valves are necessary that inherently therefore will hold more heat energy.
