Originally posted by 99yam40
View Post
The reference to the F150 and other engine was because Rodbolt indicated the relief valve was in one of those area's initially, THAT's why I posted those pic's, to help LOCATE the valve. Doesn't take a brain surgeon to know their completly different engines. Never said they were..
The oil relief valve is now believed to be in the oil pump (agreed).
Its NOT shown or mentioned in the shop manual and you won't find the relief valve available on ANY parts fisch.
The low oil pressure alarm light is activating and is verified by a mechanical gauge showing low pressure.
I don't need ANY manual to know there's an issue there, that's common sense..The system is telling you there's low oil pressure, its confirmed, mechanically and compared to an adjacent, identical engine (15-20 PSI vs 70 or so PSI)
Most oil filters have a by pass valve built inside as well even if the the filter clogs up (I assume the yamaha filter has the same).
*Bottom line, what needs to be done/replaced, etc (that already hasn't been done) to fix the oil pressure? Your thoughts?
