I just came across fuel pump update kit that is for early F225 and others. Does anyone no why this was issued,how long has it been around for. I was wondering if it was it fix the fuel issues like the one I have.
Fuel Pump update ki 69j 244b0-09
From what I have found out, the original 69J-24410-00-00, 69J-24410-01-00, and 69J-24410-02-00 pumps are no longer available. It appears that if a replacement pump is needed then the kit is available so that a different part number pump can be adapted to a motor that did not come with the replacement pump that is within the kit.
I don't think/guess that the pump in the updated kit will solve your problem. But I can't say that it won't either.
Originally posted by boscoe99 View PostFrom what I have found out, the original 69J-24410-00-00, 69J-24410-01-00, and 69J-24410-02-00 pumps are no longer available. It appears that if a replacement pump is needed then the kit is available so that a different part number pump can be adapted to a motor that did not come with the replacement pump that is within the kit.
wonder when it came about - too bad we can't see the entirety of the "installation instructions".
Also another example of Munao's excellence; he provides information on his site that is simply unavailable (to the public) elsewhere
Trying to get a copy of the kit instructions. If any. Yamaha has been known to issue kits with no instructions.
Kit purportedly has instructions within it. Part number of the new pump is not yet known by Yamaha US. They are trying to get it from Japan.
Fred I am thinking the same as you with respect to the fuse. Hopefully the new pump is not as prone to blowing fuses as the old one is/was.Last edited by boscoe99; 10-25-2018, 04:15 PM.
Originally posted by fairdeal View Postthe fuse for the original pump is 5A - assume that is different for this new pump,
hence a new fuse (and spare)
The updated F225 uses a different part number LP pump. Is it the same as that in the kit? Don't know yet.
