Hi All, I have 2002 50hp Yamaha (pre mix version). I had it serviced not long ago and ever since I think it is running too rich. The reason being whenever idling out on the water or motoring around at low speed the motor starts to run rough (like it is missing) and gets quite smoky. When the throttle opens up it misses and splutters for a moment before clearing and opening up nicely.
The problem is whenever I go to tune it at home out of the water on the muffs it will idle perfectly all day with little to no smoke and it will give a nice burst of smoke from the exhaust when you give it a short sharp rev then the smoke clears quickly which makes me think it is right... Hence the confusion.
I am running 50:1 mix of yamilube 2 stroke oil with 95 octane fuel, always fresh.
My question: should I dial the mixture screws back more (leaner) given all I have said above? ( I don't want to run it too lean for fear of doing damage to the motor) The problem only seems to be when under load so could there be another issue?
