I have a pair of 2002 F60s (138 hours). Yesterday one spat some mashed up rubber through the prop exhaust and started to make a grinding sound under load and the prop stopped driving also under load (the motor just spun up to max revs). The gears engage / disengage correctly and the prop spins OK when there is no load on it.
I am guessing this is some sort of clutch and seal problem.
What do you reckon I need to do to fix this situation?
I do have good mechanical skills and adverse to stripping and rebuilding.
Yes, the water pump is working properly and delivering a strong telltale stream.
The boat lives on water and there is no trailer or easy way to get it out.
JJ
JJ
