Yamaha 2002 115 4 stroke with 704 Controls
  • Yamaha 2002 115 4 stroke with 704 Controls
    Issue: Went out Saturday, engine runs strong and tops off around 5800 RPM as usual - sounds great. After a 12 mile run and pulling back, noticed when advancing the 704 Control throttle, would top off at 4700 RPM. Still sounded fine and ran great for next 3 hours, except couldn't get to historical 5800 RPM top end. When pushing throttle up at 4700 (looking for that last 15%), RPMs would drop to 4500, 4200 and hang there. Don't know if there is some mechanical slippage occuring at Control Box or on outboard. Repeat - engine runs great, sounds great . . . just can't get past the 4700 RPM mark now. Idease?
    fix your fuel issue.
    nothing slipped.
      Can you be more specific on "fix your fuel issue"? The 115 runs smooth, no sputter or burps. New fuel / water separator.
        you can simply look at the linkage on the engine to see if its fully open.
        my bet is a clogged VST filter or low rail pressure or partially clogged injector filters.
