I own twin 2006 F250's (TXR's) with 1,585 hours.
All year long, I have been flushing each engine with two garden hoses: 1 with muffs for 8-10 minutes after use + a 2nd hose attached to the garden hose fitting.
Just this past week, my port engine suddenly no longer has the pee water stream! This happens whether on both the muffs + garden hose fitting (engine running) or just the garden hose fitting (engine off and tilted up).
I replaced the water pump impeller (the previous one looked perfect and only had 170 hours on it). I also put a soft wire up the tell tale outlet some 12" - no clogs or restriction. I removed the black tell tale hose off the output fitting that goes through the lower housing and I can blow air up into the tell tale line with no restriction.
With the boat and engine in the water, my engine however has a strong water stream at both idle and at higher RPM's. No overheat alarms.
So... Any ideas what could suddenly cause my pee stream to stop when flushing no matter how I do it?
Might this have something to do with the poppet valve? I can't think of anything else.
Thanks,
Jack
Thanks,
Jack
