Since it is so easy to obtain a voltage calculator on the innerweb, what's the point in buying a peak voltage adapter or peak voltage reading meter? Alternatively, data indicates that RMS (typical voltmeter) voltage can be converted to peak voltage by multiplying voltmeter reading by 1.414.
Am I misunderstanding anything?
fairdeal, are you interested in taking some peak voltage measurements to verify that the calculators are correct?
