one of my 2012 Yamaha F150's has been leaking engine oil down the front of lower unit for couple years. I pulled power head and installed new oil pump and crank seal and base gasket, still leaks. The leak isnt bad enough to where it uses oil just gets the front of leg damp. Now the second motor is starting the same thing. I always run my oil level within a 1/8" of full mark. Research shows it should be run half way between the two...could this be causing the problem? I'm at my wits end on this. And no its not from filter changes and doesnt leak enough to use a dye. Any thoughts?
Thanks...
Thanks...
