2001 HDPI 175. Starts great. Gets harder and harder to crank as the day goes on. Low pressure fuel pumps?
Low Pressure Fuel Pumps
Harder to crank or harder to start?
Crank is the starter motor rotating the motor. Starting is the engine just beginning to run.
I don't see the low pressure fuel pumps being either issue. The motor uses a high pressure mechanical fuel pump to provide fuel to the injectors. A medium pressure electrical fuel pump provides fuel to the HP pump. The low pressure pumps merely keep a small tank filled with gasoline, in which the electric fuel pump is positioned.
You can pump the primer ball to do what the low pressure pumps do. If that fixes the problem then it would appear to be the low pressure fuel pumps. I don't think that is the problem however.
