Good day to all... I need some help. I recently changed the water pump on my 250 like I always have. Original owner of this engine. When i cranked it up and started pulling out of the ramp I noticed a clunking noise come and go but not consistent. its loud. Now it only does it in idle speed from 600 - 900 RPMs. after that it goes away and everything is fine. Here is what ive tried
1) removed pump and reinstall new wave washers and pulled up on shaft while installing the washers and retainer. NO lUCK same noise
2) when I remove the prop it does not make the noise while in gear or at all.
3) reinstall prop and same noise again.
4) My mechanic says its the shaft making that noise no problem wont harm anything. Yamah is known for this problem.
Sorry I cant take that noise it sounds like something is going to pop out of there. I go out with the family and would not like to brake down while dolphin fishing.
Can anyone help??
Can anyone help??
