My buzzer sounds after extended cranking,no start.Is this because of low volts to ecu,? starts fast after charge to batt,this normal?Time for batt?
04 F115 Buzzer
I am fairly sure some motors had an alarm for low voltage, but I could be wrong
with a complete Model # (motor ID) I am sure someone could tell you for sure.
And I am sure if the motor does not turn fast enough and has low voltage while cranking it could keep some motors from sparking properly
read here about flashing on gauge,its a TXRC,it does sound with lanyard off.Much appreciated!Last edited by silversides; 09-17-2018, 08:17 PM.
Your primary issue is "extended cranking" itself.
An EFI engine should start within a second or so of cranking -
correct whatever is preventing it from starting
and then you don't have to worry about the buzzer.
Originally posted by silversides View Postowners manual only talks about flashing on gauge,its a TXRC,it does sound with lanyard off.Much appreciated!
Fully charge the battery and get it LOAD TESTED... Basic's first..
As stated above, there shouldn't be ANY extended cranking..Scott
where does this flashing come into play
Some tachometers will flash for an over temperature event, a low oil event or a low oil pressure event.
so does his motor have a low voltage alarm and if it does would it flash on gauge also or just buz
Read about flashing here,i'm guessing oil, temp icons.Charged batt will load test.Curious if alarm sounding is telling me low volts.By extended crank i'm talking 5-6sec.
Originally posted by silversides View PostRead about flashing here,i'm guessing oil, temp icons.Charged batt will load test.Curious if alarm sounding is telling me low volts.By extended crank i'm talking 5-6sec.
yes,digital tach oil ,temp icons,eng hrs trim bar. Thanks again for your knowledgeLast edited by silversides; 09-17-2018, 08:41 PM.
Originally posted by silversides View Postyes,digital tach oil ,temp icons,eng hrs trim bar. Thanks again for your knowledge
Thanks for the explanation, does the buzzer sound also when that happens?
Generally low voltage can cause any one or more of a number of silly things to happen. A light or lights may flash, the horn may sound, the motor may go into RPM reduction mode, or the motor may simply quit running.
OK I thought I had read some motor had a low voltage warning alarm.
does this F115 have an ignition system that could be affected by low voltage?
maybe that could cause the long crank time before firing up, with a bad battery or bad connection
ÂÂÂÂÂÂÂ
