I have a 2004 HPDI (2.6L). I am not getting oil flow from the remote tank to the main tank. Here is what i have checked so far:
1. the remote pump works if I apply 12 volts.
2. the remote pump works if i use the emergency fill switch.
3. the main tank float test good (at all 3 levels) and the remote tank float checks OK (one level).
4. I have continuity on all 4 wires from the remote tank to the first plug inside the cowling (Blue; Black; Black/Red; and Brown).
5. I have continuity from the first plug to the plug going into the CDI unit (on the same color wires except Brown changes to Yellow).
6. I have continuity from the CDI plug to the plug at the main tank harness.
7. When I jump from L/G to B in the harness at the float connection the pump should come on but it DOES NOT.
8. I do NOT have a tach with lights (only an alarm horn).
So is the only thing left the CDI unit (I hope not)???
