i Guys,
I'm in some serious need of professional help with regards to my OX66 outboard.
First off, I'm based in South-Africa and the OX66 was not sold by Yamaha SA - so they refuse to have a look at the motor. This motor was built by a local guy that traded me for my blown HPDI 250 powerhead(this seemed like a good idea as there are quite a few people who feel that the OX66 was the best 2-stroke yamaha ever built and I obviously don't want to be caught with another blown powerhead). With this said, I cannot tell you which year model the motor is - but rather give you a list of parts with their part numbers that's currently on the motor.
So let me explain the problem that I'm experiencing:
Motor starts fine at home and I idle it for a few seconds and then I have to switch it off as I don't have water running through it, so I'd rather be safe.
Depending on the day, when I get to the dam the motor will at least start and I can drive around (stopping and starting) for a good few hours and then will just not start again. Then there are those other days where I get to the dam and the motor will start with the boat being launched and then after idling for a few minutes (which I normally do to warm the motor up) it just dies and will not come back to life again.
From what I can tell there's no spark, I removed one of the plugs (re-attached the lead) and held it against a clean shiny bolt on the cylinder head while cranking the motor.
Things that I've checked or had checked:
-Injectors
-Fuel Pressure
-Swapped CDIs with someone that's also running an OX66.
-Different Cranking Batteries.
-Atmospheric Pressure sensor.
-Intake Air Temperature sensor.
-Throttle position sensor.
-Charge Coil Voltage.
-Compression Test.
-Replaced VST.
-Serviced the 3 LP-fuel pumps
-Replaced Fuel Pump Regulator/Resistor.
I think the main culprit here is the Pulser coil, but I don't have a Peak Voltage meter to test this. I have ordered a new Pulser coil and will take a few weeks to get here.
So any ideas or pointers on how to find this problem will be highly appreciated.
-Injectors
-Fuel Pressure
-Compression Test.
-Replaced VST.
