2005 90 2 stroke trim unit
  • 2005 90 2 stroke trim unit
    I ordered and installed this used trim unit from flea bay, works good out of the water. In the water it will
    trim the engine at 1/4 throttle but not at full throttle. I am waiting for the customer to get the boat back
    to me to water test it.
    interesting, sounds like it does not have enough pressure to overcome the load put on it under heavy RPM.
    but then is there more load while it is up on plane or when plowing?
      I am jut going off of what the customer is telling me. I will water test it tomorrow.
        Maybe that's why it was sold on flea bay?.......faulty unit..
          may just be the pressure relief valve screw isnt screwed in all the way. Mine did this when it was new on 1st day of breaking it in and it was just the pressure relief valve that wasnt screwed in all the way.
            I would think if that was the problem it would not stay up even under low RPM, but does not cost anything to check it to make sure it is snugged up.
            he said it would not trim up, not that it would drop back down or stay where it was set at.
            sounds like some of the old power tilt but not trim set ups
            Walleye1 will find out what is happening soon and get back to us.
              It was the relief valve
                Very interesting, I would not have thought that it would only affect high speed trimming
