I have purchased a 2015 Key West 203 FS with a Yamaha 175 hp outboard. The console has analog Yamaha gauges (speed, tachometer and fuel) and want to add a trim meter to the group. What all do I need for a total install? I am assuming the wiring harness already has the signal wire from the motor to the wiring block inside the console. As a side note, the fuel gauge is all over the place and when full most times reads between 1/2 and 3/4.
Adding Tilt Gauge Yamaha 175
Originally posted by rdalepeak View PostAs a side note, the fuel gauge is all over the place and when full most times reads between 1/2 and 3/4.
hopefully under a convenient access plate on the deck
and identify the brand
there are "lesser quality" sending units in existence, using swing arms
with numerous failure modes
but the WEMA is very reliable -
the typical problem being simply a bad wiring connection, or corroded wire
external to the sender itself.
a reading erroneously low would generally be a poor ground
Wow... thanks for the great information! One final question... what would the part number that I would have to purchase for the sending unit on the motor itself?
Originally posted by rdalepeak View Post***... thanks for the great information! One final question... what would the part number that I would have to purchase for the sending unit on the motor itself?
When it comes to the fuel tank sender I am very partial to this brand. All solid state. No moving parts.
99.999% of the time it is the sender. If not the sender, then the ground.
www.centroidproducts.comLast edited by boscoe99; 08-20-2018, 05:55 PM.
Originally posted by rdalepeak View PostOMG, I forgot I had the warranty id card in my billfold... engine model F175XAScott
Well... how about that?!? One less thing to worry with! Thank one and all for your help. I really appreciate it. My apologies for my obvious lack of Yamaha knowledge.
Originally posted by rdalepeak View PostWell... how about that?!? One less thing to worry with! Thank one and all for your help. I really appreciate it. My apologies for my obvious lack of Yamaha knowledge.
If you click above on purchase "Buy Yamaha Outboard Parts" above, then enter your information, you'll bring up parts diagrams for about everything.
Being your engine is NOT a US version,(your EXACT model # isn't there), I clicked on a model close to yours...
It's very helpful, especially when tearing down something or re-assembly.Scott
ÂÂÂÂÂÂ
