No codes from the Capt. Obvious method. I'll try the software after I digest the manual for YDS.
So no known past occurances with "Check Engine" flashing on square guages?
"Check Engine" on Guage
The OP did. I was responding to rodnuts comment that only Command Link instruments have a check engine function.
Leave a comment:
????? What?????
Below is from a VZ200/225/250/300 Owner's manual with reference to funtionality of the conventional multi-function tachometer.
Someone slept while in the school house it appears. Now it won't display codes but it can display a check engine icon.
Leave a comment:
Originally posted by rodbolt17 View Postnot wishing to be capt obvious here, but ONLY command link can display check engine. use the tool twixt the ears.
read the freaking manual.
Leave a comment:
Originally posted by No Bail View PostRODBOLT17, YOU ARE CAPTAIN OBVIOUS. And ensign oblivious.
I suppose I could drive 2 hours to the boat to get my manual. Or you could be helpful. Likely not both.
Leave a comment:
Leave a comment:
Leave a comment:
Thanks. I don't believe that my gauges are the type, so my engines probably don't have the capability. The whole thing was sold new as a package. Sorry to derail the thread.
Leave a comment:
Two things minimum are needed. The engine needs to be Command Link capable and the gauges need to the Command Link type. Or an NMEA 2000 display used in the place of a CL gauge.
Leave a comment:
I can't answer those questions as I am not near the boat. As near as I can tell from looking online, I do not have these type gauges. The display appears different than mine. But, I will check next time I pop the cowl.
Many thanks.
Leave a comment:
Originally posted by oldmako69 View PostHow do you determine if you have Command Link? I don't recall seeing anything about this feature in the owners manual. Do my 2005 F225 TURD's have that? If so, where are the codes displayed, explained?
Leave a comment:
Leave a comment:
