Disregard the title of this thread....
'98 S115TLRW
Been experiencing ugly sounds coming from PTT....squeaking, squealing, crunching....all sounds not heard when I first acquired this engine 2 years ago. Referring to my service manual, air bleeding is recommended when experiencing "rough operation". Opened the reservior and the color of PTT fluid you see pictured below is what came out.
Not sure how clear the photo will be on your end...the color of the fluid is lavender...not purple, not white, not clear, but somewhere in between these colors on the color spectrum. The 2nd photo is the fluid color against the white backdrop of my transom.
So at first I thought/hoped this issue was air-related. But by looking at the fluid it's clearly not. I'm not 100% of all the varying colors of ATF fluid....but I'm pretty certain lavender is not one of these. That milky color can only mean one thing, no?...Leaky seal.
If so, my next question is how do I go about identifying which seal or seals are bad. Also something to consider...this engine is 20 years old. I'm not the original owner. Despite this engine having been meticulously maintained throughout the years during and prior to my ownership, let's assume for the sake of simplicity that this PTT is original. No variation of paint color between PTT unit, lower unit, lower/upper cowling.
How old is the fluid? No idea. I've never changed it because I've had no reason to change. So could this color of fluid be attributed to the age of the PTT system and/or the age of the fluid and not a busted seal, thus the unit only needs to be air bled? I don't know. I suppose I could remove the reservoir, drain the fluid, replace reservoir, then fill with new fluid. Check fluid color after a few excursions. If milky, busted seal. If no issues with PTT and fluid is same color as when I filled....problem solved.
Your thoughts?
'98 S115TLRW
Your thoughts?
