Introduction and lots of questions
  • Introduction and lots of questions
    Hi all. First time on this site. I use the other sites but seldom get a response hope this is a more active site so here goes.
    2001 Yamaha F115 200 hours.
    1.) Checked the oil and it is way overfull. I suspect the sinister "making oil" syndrome has struck so I pull the thermostat ad WA LA!! Thermostat stuck wide open. I have ordered a replacement.
    Do you think this is 100% of the cause of getting extra fluid in my crank case?
    2.) Independent of the above issue, should I preemptively service the VST since I am around 200 hours and 12 years old? or should I wait till I have an issue? I have been religious about keeping good fuel and fuel treatment in it and it has always run very well.
    Any 200 hour service suggestions?
    Thanks!!!
    2002 19ft. Baystealth 1888 with Yamaha F115 (4 stroke)
    2002 15ft Alumacraft with 25 Yamaha 4 stroke
    I can't surmise that the thermostat being stuck open is 100% the cause of your problem but a stuck thermostat is known to cause, or contribute to, the making oil issue. Put the new one in and see what happens.
    On a 12/13 year old motor I would change the VST filter just for the hell of it. I might also go so far as to remove the injectors and send them out to be tested and cleaned.
    Other stuff to do
    water pump r and r and grease the drive shaft splines while you are at it
    gear oil r and r
    motor oil r and r
    fuel filter r and r
    timing belt r and r
    check plugs and replace if needed
    inspect for corrosion
    check the anodes
    Is this a saltwater or freshwater usage motor? Have you owned the motor since new or did you get it used?
      Thanks Bascoe!
      I am the original owner
      I plan on doing the basics, all the oil and spark plugs as well as the fuel filters ( I also have a spin on 10-micron)
      Timing belt? yep probably need to look in to that.
      Fuel injectors....might as well yank em if I service the VST
      Water pump got swapped out a couple of years ago, but I'm sure it wouldn't hurt.
      I have read about a busted diaphragm in the fuel pump cause fuel to enter the crankcase, does that apply to fuel injected models and if so how do I check for that?
        PBF115, I went through my F90TLR last yr and had the fuel injectors cleaned. The guy did a great job and was reasonable. If you email me at jackmanjls@gmail.com I will send the injectors guys name. I'm reluctant to post his name on this forum...I don't know if they allow that.
          putting your e mail on here is not a very smart thing to do
          Spammers can get a hold of it too easy
          Private Messages is the best way to go.
          that way it is not up for everyone to see
            a ruptured/leaking pump diaphragm can and will make oil.
            so will overpropping an EFI 4 stroke.
              Thanks!
              I am positive I am NOT over-propped.
              How to you detect/test for an issue with the diaphragm?
                .....Looking at the diagram in my service manual I see two fuel pump diaphragms, one is about $2 bucks the other is about $40. I guess I could take the pump apart and inspect it?
