Hello all,
I am working on a 2006 Yamaha F225 TXR SER# 693X1026640K. I'm not sure if all those are needed for id but thats all on the sticker.
Now to the problem: I had a major water in fuel tank issue. Finally got all cleaned, new lines, filters(3 total), and fuel pumps. feed and vst pump. Went to test on water and ran for a few minutes then slowly lost rpm and dies. If I cycle key, it will start and run for about 60 seconds then loses rpm until dead. Got it back home finally, put on pressure gauge at schrader valve. It runs up to 40 psi with key on but loses pressure as soon as key is off. I noticed as rpm is lost, so is fuel pressure. Drops from 40 to zero. Cycle key couple times and it comes up but wont hold when shut down but it will start and run until pressure loss. I also noticed my feed pump is running constantly with engine on. I know they are supposed to cycle as needed. Do I have an issue inside vst where the fuel is being returned constantly causing feed pump to run all the time? Or do I have a high pressure pump that's failing inside tank?. Should I remove vst for inspection of inside components? Could a bad float or needle/seat cause psi issue as well as feed pump running constantly? I don't want to throw parts at it, but I am lost here.
Thanks in advance for any clues!!
Spencer
Spencer
